TwinTurbo.NET: Nissan 300ZX forum - Corroded electrical connectors are a big cause of
Subject Corroded electrical connectors are a big cause of
Posted by doug8867 on June 28, 2008 at 9:45 PM
  This message has been viewed 175 times.
In Reply To any suggestions posted by badluck on June 27, 2008 at 09:55 PM
Message intermittent hesitation problems. To clean them you will need a pic set
available at big box hardware store to remove the connector clips and
scrape off the corrosion, and some electrical contact cleaner, then coat
the connector with dielectric grease afterward.
Connectors to check for the greenish corrosion are:
TPS, 6 injectors, (coolant temp sensor - usually yellow or red on radiator
pipe in front) (air regulator, AAC connector. - yellow and light blue
connectors at right rear top of engine)
Here's a link to some pics of various parts.
[ http://www.z32photoguide.com/index.html ]
Hope that helps.
ps. O2 sensors could be culprit in failed emissions. There is an O2 sensor
test you can perform to see if yours are working properly. Look in the
TECH page of this site for "ecu self diagnostics" for info.
